Thanks for the help guys....guess I should've done the 'cures' one at a time but it's sunday night....anyway, have turned the pump speed up and dropped the temp on the tanks built in thermostat and bingo...(well so far at least) the tank now cuts out the boiler without the reset tripping.
It was a 'Smartline E210' tank and comes with all the valves, vessels and everything in the box.....even the bits of pipe are labled 'A', 'B', 'C' etc.
There are two fittings on the top (in=cold, out=hot) and the feed and return heating loop fittings on the side......obviously there is quite a lot of safety & drain tundish vales and pipework as well, but the tank fitted was the same make and model, just the 130 ltr instead of the 210 ltr. The central heating expansion etc was for a 12 rad system....and apart from the one rad in the bathroom, they haven't yet been used (isolated) awaiting the decorating.
There is only one mid port valve though....I will speak to the engineer about the other one to be fitted for safety....could you explain a little so I could pass on the info to him...miserable git he is !
I changed the tank myself cos he said he wouldn't do it....needless to say, now I've done it myself he's not the most helpful of gents.
Thanks for the info on the boiler...it heats fine....from dead cold to tripping out in about 1.5/1.25 hrs....when the button stays up !
And one thing with my job....when it does go bang....there are no witnesses !!!!
Once again guys, thanks for your help......
