I think posting my corgi number on the site is not a very clever idea.
However useful and informative discussion/chat on the subject matter is most welcome.
i have just recently moved house and fitted is a promax 24he.The problem i am having is with the fan,sometimes it will start and sometimes it wont.
I had a look and it seems that the fan will only start when it stops in a certain position.When it wont start if you give it a little spin it works fine.when turned off and then on again its 50 50 if it will start again.
Any ideas,is it the control pcb or the fan itself.
Check the bearings on the fan. Are there signs of roughness or excessive play? Are the electrical connections sound? When the fan is running, does it seem a bit feeble? Is there a smell of burning from fan windings? Chances are you need a new fan .
hello and thanks for the feedback.
there does not seem to be any water marks or stains on the pcb on the fan.The fan could well be able to run at variable speeds but seems to run at a constant speed.The fan is a 24vdc brushless type and all electrical connections are fine,when the fan is running it sounds in a1 condition.
I think it is a problem with some electronic device but dont know whether it it is on the fan circuit itself or the control board on the boiler.
sorry for not letting you know but i am a electrician so have allready looked for the obvious things.
thanks and look forward to hearing your comments
Bozobro
