I was looking for some help with a couple of problems with my central heating system.
I have recently moved into a house that has Potterton Promax HE - it was installed in 2003.
The main problem is noise on the system. This happens when the system gets hot - there is a humming noise as though a kettle is boiling. The system is quiet for about 15 minutes but when the radiators get very hot it starts. The thermostat in the house is set to 20c.
Looking at forums it seems turning the boilet temp down may cure this although there is no such control on the boiler itself.
The is no air in the system when i go to bleed the radiators.
Any help would be much appreciated.
The other problem is the boilet leaks slightly when not in use. As in, if it is switched off for a couple of days there will be a very slight drip although I can not se where this is coming from in the boiler,
Again any help would be appreciated - i wasn't sure if this was a common problem with this boiler?
Many thanks
Nick
Many thanks
Nick
