Hi All,
I really wish I'd found this forum a long time ago!
Our boiler has just started to exhibit the above behaviour. I've bled all the rads and checked the pressure to be 1 bar. If we have the C/H on then there is no problem, if we run a hot tap no problem, but is we are doing neither the boiler is still heating water, and I'm guessing eventually cutting out due to some safety valve, as the boiler makes a banging noise, and eventually the pilot light goes out.
The boiler is fine if left on stand by and only turned on when we need to have hot water or run the C/H, then turned back to standby.
I've replace the PCB in the past, so I've had the front off, but I've not gone any further than that.
Is this something I can look at myself in the first instance, if not - croydoncorgi, you've been very helpful to others in the forum so you must be a reasonable guy so if you'd like a little work... I'm in Thornton Heath.
Thanks in advance for all help and advice!
_________________________
Moderator
email address removed, these can be shown in your profile
Moderator
