Hi all,
Can anybody throw some light onto a little problem please??
I recently moved to a new house where I have a Potterton Puma combi boiler installed. All has been fine up until a few weeks ago.......... For absolutely no reason at all, the boiler will fire up and I will get FULL central heating even though the "constant" and "timed" switch is set to off........With being at work all week, I dont even have the time clock set to come on at various times, in fact I thought it was the clock itself that was a bit faulty so one evening I disconnected it completely but, to no avail.
It will come on, disregarding the temperature setting on the front and even if the thermostatic valves on the rads are set to off, I end up with scorching red hot radiators throughout the house.
I end up having to turn the entire boiler off at the mains, waiting a few hours and then turning it back on.
Any advice you can give would be greatly appreciated - Its not so bad if I'm actually in the house to catch it but, if it does it when I'm not here, my gas bills are going to be astronomical!!!!
Thank you.
Thank you.
