- Joined
- 5 Nov 2010
- Messages
- 389
- Reaction score
- 3
- Country
It's not one of those.Would it be possible to power this masthead amplifier using the feed to the light switch?
The amplifier in the picture is powered by 12 volts sent UP one of the co-ax cables that come from the mast head amplifier outputs. ( Signal OUT power IN )
The PSU goes behind any one of the televisions.
The lead from the mast head amplifier goes into one of the sockets on the PSU ( SIGNAL IN 12 volts OUT ) and a lead from the other socket on the PSU connects to the TV aerial socket.
Whoaa! Game changer
I now know what you mean. It took me a while because I couldn't get my head round the fact one cable will have the signal going one direction yet power going the other - had to go away for a while and use Google & YouTube!
After reading a review on Amazon from a previous purchaser about how he already had a socket in his loft I assumed it had to be that way. I also thought you fed the cable from the mast into the PSU which amplified the signal then from the PSU to the splitter (as I call it). Managed to find a large image of the splitter to read the print on it.
I also read there's 2 ways of boosting the signal. I hope this way isn't a glorified version of the ones you get from Argos that people moan about having no effect. That being said, I've just checked Argos and the reviews now seem to be fairly positive, so much so, that I'm thinking of getting this instead since it seems simpler and less hassle. Is this the same thing and just as good?
I realise this is going almost completely off the original question but it's starting to look like I don't need a PSU in the loft, therefore no power socket needed! At least it's still to do with electrical
