Following our power cut problems, I want to replace my Castle caretech 1700Mk2 panel and keypad as the 64 pin processor has blown and I can't find a replacement. I've had a quote of £420 which is a lot for a poor old pensioner so I'm hoping to do it myself. I've looked on the Castle site and they recommend their Euro 76 panel which has enough in/outputs to cover Fort Knox! Wouldn't the Euro Mini 10 do the trick? It's a domestic installation with 8 zones and just the 1 input position. I want to use existing wiring and sensors and just replace the panel and keypad and add a panic button. Any help would be appreciated.
Yes it would do fine, but, castle is not a diy panel and i would put money on you struggling with programming (no offense intended there btw)
If you're gonna diy, have a look at some texecom gear, they have a range aimed at the diy end, easy to install and programmed out the box.
