Power for Kitchen Appliances?
29 Jun 2006
Birmingham
Any recommendations for switching on power to my washing machine and dishwasher which are full size models (not integrated), and will be housed in a custom made cabinet?
Currently the cable is fed through a hole in the worktop and I plug this into a nearby socket and switch on when needed. If left plugged in the standby light remains on both appliances. Is there a better way to have these connected to the power and switched by a separate switch on the wall or something?
I'd also like to apply the technique to switch on some plinth lights which will be running off a transformer.
Thanks in advance. :)
One good way is to have a 20A DP switch with neon above the worktop, feeding an unswitched socket outlet directly below.
For things like cooker hoods and pelmet lamps that are fixed to the wall and do not benefit from a plug, use an FCU with (e.g.) a 3A or 5A fuse, feeding a flex outlet above.
You can lay out these switches and FCUs in a row with the socket outlets that you will also have above the worktop. The cable can run horizontally between them, which is economical in labour and materials.
Some regulations apply to electrical work in Kitchens and bathrooms in England and Wales (there is a very informative post on here ....).
edited - here it is //www.diynot.com/forums/viewtopic.php?p=327999#327999
