Hi
Just want to run this by the experts to make sure it would be ok
Planning on getting power to an outside shed, for 1 socket.
Because of the existing setup etc I was going to utilise an existing circuit that is no longer used.
MK CU with RCD - 15A MCB
20 metre run in total - ~5m in 2.5mm T&E, joining to 2.5mm 3 core SWA for the remainder (buried for about 10m). Terminated into a CU at shed end with 15A MCB for the socket.
I think volt drop etc will be ok for this length of run and 2.5 will just do the job.
Does that sound ok?
Cheers
Neil
Does that sound ok?
Cheers
Neil
