Power shower connections
this is a wall plate
where you in essex ?
15 x 15 is no good to you. and no they don't only a 15 x 15 elbow compression.
you need 1/2" to screw the shower outlet into.
why do you want a 15 x 15 ?
get them in bq, screwfix in pipps hill ind
the list is endless in basildon.
I guessed I need 15mm x 15mm as the copper pipe is 15mm and the 15mm nuts on the compression joints fit nicely on the shower connectors
ok
but the other end still needs to be 1/2" bsp thread for the shower out to screw in.
not 15mm compression.
