Well. Ive tried scanning through all posts but still need to clear up a few things... I'm installing a new shower, hot water from indirect 110litre cylinder at ground floor, cold water from mains feed at about 3 bar, shower at first floor level, shower head will be about 1.4m below base of header tank. Hot water cylinder one floor and about 6m away from shower. My problems are;
To get a guaranteed good flow from the shower I guess I need a pumped system due to low hot water pressure.
Pump would need to take mains pressure feed as there would be a tortuous route to bring a new cold feed down from the header tank.
Pump position would require to be close to the shower and some distance from the hot water cylinder, otherwise the pump would be feeding all the other hot water outlets in the house.
Can I site the pump remote from the cylinder and near the shower?
Can I connect the cold mains to the pump via a pressure reducing valve?
If so what type of valve?
Do I need a one way valve fitted to the hot supply to prevent backflow to the cylinder.
Do I need to increase the size of my hot water cylinder to cater for the flow rates in the pumped system?
Any help would be excellent.
JA
JA
