power tool for cutting floor boards
2 Jan 2011
Kent
i want a saw for cutting floorboards,but not to big have used a chunky old circular saw before but want something smaller,any ideas :D
I usually use a reciprocating saw.
Haha, not so well when they are in situ!
You can get a small circular saw, I had a Skil one once, it lasted years and years but finally gave up the ghost when I foolishly used it to cut up 11 old 1920's doors into small fire wood for the wood burner :(
a multi tool will cut them in situ and be neater, but more time consuming, a circular say is quick and easy and a compound miter saw will cut then nice and accurately if your laying them.
The trouble with a circular saw is that you always cut grooves in the adjacent boards which is why I use a reciprocating saw when it matters. You can , of course, cut the T&G off and lever the board up to cut.
A flooring saw?
and to take the tonguues poff another more trad tool, the electrician's bolster
Lidl had a tool in few weeks back that looked good for cutting floor boards, It looked like a small angle grinder with a small blade about 4" with plunge facility and dust extraction It was made by parkside.
A multitool - problem is they cut very slowly and the blades cost a bomb (don't last well if you keep hittng nails, etc)
Not a multi tool. More like a cross between an angle grinder and a circular saw with maybe 80-90mm dia wheels not just for wood. It looked interesting so I picked it up and had a look at it, and it looked well made 49.99. But I already have 3 circular saws, but I have not seen anything that small before.
Yes I saw that too. It looked pretty much like a Rexon tile cutter that I've got that looks just like a small circular saw. It was the difficulty in getting new blades that put me off it.
