No competent gas engineer would be happy to do any work on your boiler if the flue cannot be inspected along all its length.
I think that it was agreed that they would be classified as At Risk in that situation and that means an advised turn off! Can anyone remember the situation in that respect?
Tony
This was the plan for a while but they found that there were far too many disgruntled customers out there so it was changed. If a flue can't be inspected through it's lengh but all checks/tests pass it's NTCS.
Particularly with powermax, one of the main points about that boiler was the fluing options. That led to the flue being boxed it on pretty much every installation!
If it is visible, it needs to be supported by purpose provided brackets every 1.8 meters (or every joint) otherwise it is At Risk.
That's the last i heard anyway..... I'm sure standards will change soon enough
