Premier Elite 24
I had a lead missing when I got my first com wifi, didnthave the lead for the external aerial, packing error, once setup correctly it works fine.
There seems to be 2 versions cek-0001 with aerial built on to the PCB for polymer and cek-0002 with external aerial for metal panels. Could this be what happened?
maybe I was thinking of a print com as they are no longer available now either.
its a device for connecting a pc modem or mobilephone, the com gsm module (tango) was about £300 touch making it expensive, this was a cheaper way of getting the gsm coms done.
It would be a cheap solution vut which mobiles could you use with it, have to be honest never used it.
the udl code can go upto 16 digits I think would have to check, but chilling out now, gyms nearly killed me.
Considering the GSM module is £150, if I can source the 6310i should I go for this?
I mean in addition to the com-wifi.
At around £30 to £50 on ebay for the phone and £20 for the lead it is still cheaper than the the com gsm unit. I can't see why it wouldn't work on the new panels but I haven't tried it.
@paul, think that ATS issue is not related to the comwifi, I have a different system with com-ip and gsm unit and the ats fault occurs on that occasionally so the com wifi isn't the issue.
Also have comwifi system that has a similar issue, however both systems don't show the fault at the same time, and I cant track it down, I am looking at the optimum ATS delay. I am at some point going to setup Montex and texbase up and test that and see if I can prove its the server rather end being the problem, but it isn't a test that's done over night.
I had a similar theory about the issues being at the server end although I'm unsure of the extent of Texecoms I.T. infustructure. Would they use redundant cluster servers or is their push server just a single machine sat in a cabinet somewhere that gets rebooted when updates etc. are applied although you said your numours systems loose connection at different times.
My account no. is in the low 500's so they're not servicing that many customers and without a subscription model I wouldn't expect the IT side to get that much R&D.
Are you sure that is the correct cable? That has a serial port, how would that connect to a 6310i's fbus port?
