I live in a Victorian terrace house (built around 1840) and I am currently re-doing to bedrooms on the top floor.
I've removed all of the old plaster and lath, so that it is now back to the brickwork. I've also had the rendering on the outside sorted out, as this was shot and causing penetrating damp. I'm now waiting for the wall to dry out before I start to decorate the wall. I just want to double check what I plan to do is sensible.
At the moment the plan is to
1) install a layer of insulation boards, either bonded or screwed into the walls.
2) install some batons for securing the plasterboard and future fixings,such as curtains
3) Plasterboard
4) Skim coat of plaster
5) Various finishing touches, such as paint, curtains and skirting board
I plan to do most of it myself, with the exception of the skim of plaster where I will get a professional.
I just want to check that this is a sensible plan of action? Have I missed any important steps. There is no pipe work or electrics on this side of the room, so that is not an issue.
I also have the following questions
1) The pointing is not looking in great shape. For the most part it is okay, but in some parts is completely deteriorated. Should I get this sorted out, or is it not a big issue? Is this a job for a professional? Or is it a reasonable DIY job?
2) What is the best order of installation for the insulation boards and the batons? For example, can I put the batons on the outside of the insulation board, with the fixings going through the baton, insulation board and then into the masonry? Or would it be better to have gaps between the insulation boards where I put the batons?
Thanks in advance for any advice.
3) Plasterboard
