Hi guys,
I'm ready to start my en-suite and considering the length of time and problems I had doing the minor job in our master bathroom (some of you will have read all about that) I thought I'd ask for advice first before I drive in and make a hash of it! lol
Right... here's the plan. I've drawn a diagram to give you an idea of what I'm working with and the plan of action to stop the damp coming through our solid construted walls of our 65yr old house with no cavity.
The walls are cleared and back to brick by the way and the skirting boards are all off. The intention it to tile the whole shower enclosure area and fit a tray and shower screen we bought from bathstore. I'm only tiling this are plus some splash back areas beacuse the tiles are expensive and the ceiling in our old house are so high.... therefore costing a fortune! The intention for the floor is to tile it.
I'm go a big roll of Oldroyd P membrane (http://www.safeguardeurope.com/products/oldroyd_p.php) and have used it a few of our bedrooms. It works really well and has fixe many of our damp problems caused by having no cavity wall. I use it with the dot and dab technique and apply 10mm plasterboard to the membrane before skimming with multifinish.
In the areas where the showers going should I use a different board? Should I be skinning with multifinish the shower enclosure walls? People have mentioned tanking? I'm guessing that this shower enclosure area will need tanking in some way or another to create a good water tight finish?
