The are many ways of doing it but I usually use one of these;
http://www.amazon.co.uk/gp/product/images/B00032II4A/ref=dp_image_0?ie=UTF8&n=79903031&s=diy
& lay it flat on the floor to cut through (across) the boards at the point where I want to remove them; i.e. against the wall or down the centre of a joist. It works surprisingly well & with a bit of practice you can cut through individual boards with minimal damage to its neighbors. Check first that there are no cables or pipes under the boards. With tongue & groove boards, take a 4” bolster chisel & hammer it down between the adjacent boards to break through the tongue either side of the first board; pick the easiest board you can get at in the centre of the floor. Lever the board up from one end to the other using a couple of pry bars; once you have the first one up the rest are relatively easy, again using the pry bars.
Depending on weather you’re lucky or not you may find enough of a joist below the wall in which case the new ply will just sit on the joist. If there is a joist within, say 4 inches of the wall, you probably wont need anything as the ply will provide sufficient support on its own & you’ve never going to get any load to speak of that close to the wall. You may need to install a sister joist (a length of wood bolted/screwed onto the existing joist) or even a series of noggins (pieces of wood fixed between the joists) to provide additional support. On the adjacent walls where the floorboards run parallel with the wall, it’s usual to fix noggins but, again, if the edge of the new ply floor is going to be in such a location where it’s unlikely ever to be subjected to any significant loading, you don’t really need anything; it’s a question of assessing individual circumstances.
Fit the new ply floor in the largest sections that practicalities will allow with joins running down the centre of a joist; any joins in the main floor area across the joists must be fully supported with noggins. Seal the back of the ply with an SBR sealant & screw it down onto the joists using suitable length screws, 150mm apart. It sounds like a lot of work but in reality with a clear room it should only take a day or so to get the new floor in place depending on how many noggins you have to put in.
Always use quality trade adhesive & grout suitable for the application, never use cheap DIY products.
