Preperation of shower area before tiling
thought you would have already had the answer to that, use a wallpaer stripper and hold it on the wall, the heat will eventually take the skimming off the wall , it will be ok if you want a cold shower , no problem.
no i am not just a tiler, although i have done several bathrooms for customers, and never had a problem, alan partridge, thats quite good,
well nuf said, does it mention if the skimming is mouldy or at all loose what you must door because it doesnt you would leave it on. You have never taken tiles off a wall and found that the skimming comes off as well and leaves the render, does this not tell you that without the skimming on it will be a better job, no sorry you wont have worked that out yet, sorry mr smiler oops tiler
So what do you say to your customers? Ok luv, I'm just going to the estate to get me wallpaper stripper cuz I'm gonna try and blast off that perfectly good finish coat. If I find bonding coat underneath then I'll have to patch up what I've removed and tile onto the finish coat anyway. If I find render underneath then happy days! I'll remove all the finish coat and tile onto the render. As I said before.... fark orf. :roll:
Try tapping the wall ,you will hear the difference between bonding and render, just try a small test area first,
I was taught by a real tradesman!
Sorry, I don't have a membership to wheeltappers and shunters club. :roll:
Oooo touched a nerve Alan? If you want to know my name, look in my profile :P
