I fitted 6 new radiators last weekend, but after refilling the system the pressure has dropped from 1.5 bar to 1.2 bar since last Sunday. I have carefully checked all the joints that I’ve made into the new radiators and there are no signs of any leaks whatsoever. All joints appear bone dry to the touch and there’s no visible signs of any leaks. Before carrying out this work I would on the odd occasion need to top the system up, but no more than a few times each year. If pressure keeps been lost at this rate I’ll be topping up virtually every week. So a few questions I have are:
1. Is this normal on refilling a pressurised system after completely draining down, possibly caused by air bubbles in the system working their way out (where water can’t get out) or other similar explanation meaning it should settle down after a short while?
2. Could I have a small leak(s) that maybe aren’t severe enough to be detected but enough to cause a pressure drop?
3. If there are any minute leaks anywhere in the system, is it advisable to try Fernox F4 leak sealer? I’ve read mixed reports on this. If I use this is it best to leave it in the system permanently or to drain down after a few days or a week of it circulating to remove it from the system?
The system is a Worcester Bosh Greenstar 28i Junior condensing combi boiler.
Thanks in advance for your help.
Tim
Tim
