Hi guys, I'm back, I'm still trying to fix this ace high boiler,
I bought a service kit for the DHW switch off ebay and it cost £28 (instead of halsteads £68 and the local merchants £45) It comes with all the innards springy bits and once you take off the big nuts ether end it fits in easily enough. No leak yeahhhh.!!!!! No ignition noooo00
I went through ignition fault finding flowchart and found the pump has seized and wasn't spinning. So I took it apart and scraped all the scale out and refitted it. it now spins freely.
The problem now
The electric water pressure switch, isn't being switched by the water pressure piston.
I have pressurised the system to 2 bar, and I call for hot water, and it fires up, I then manually press the water pressure switch, with my screwdriver, then the boiler fires up fine. So the problem now seems to be with the water pressure switch piston.
I took the 4 screws off, and checked the WPS diaphragm and it seems ok, I couldnt feel, or see a tear, I turned the water on a bit, and the water pushed up the diaphragm up..... but not when its assembled, (the piston is free its not stuck or anything)
There's tons of pressure, the pump runs... I just cant figure this out.
ideas anyone ?
[/b]
