My Nilfisk E140.2 washer has started acting up. It runs for a few minutes but if I stop and try to start again it "buzzes" loudly and then blows the fuse in the plug. I'm advised it may be the capacitor or, more likely, I'm using the wrong extension lead.
So question is can I make a larger capacity lead with 2.5mm cable with a normal socket and plug?
All the leads 16 amp leads I see have "caravan" type plug and socket.
Machine is rated at 2100 Amps.
