I have a hot-fill machine. I run the hot tap in the futility room for long enough to run hot before pressing the start button.
So as JohnW2 suggested above you 'discard' the 'hot' water until it becomes hot enough to serve the purpose.
It certainly wouldn't! However, if we're talking 40 gallons (about 150 litres if you're talking US gallons), then it's probably rather academic to be talking about 'efficiency' at all, no matter how/where all that water is heatedThe top loader is still very much the norm here - No trying to wash in a tiny puddle of water, as you put it! With up to 40 gallons or so of water for a full fill, I doubt even a relatively long pipe run would make a huge amount of difference.
I inherited such a situation, built by the Victorians, albeit it used convection loops rather than pumps - but I soon got rid of it when I discovered what energy costs it was resulting in! Admittedly, they had made some attempts to mitigate the 'wastage', by routing the loops through airing cupboards etc. ( a lot of it in 2"+ pipes!).In larger houses even in the UK we have circulation pumps to insure as soon as we turn on the tap we have hot water.
Potentially quite a long time, if it were a 3kW one - although obviously dependent on what temperature one was heating it to.Plus, of course, how long would a washing machine element take to heat forty gallons?
It is indeed. Well, a 'normal' UK HW cylinder, at least!Can it really be forty gallons? That's more than a normal hot water cylinder.
Kind Regards, John
They have plenty of 240V appliances.
I wonder how many routes for measuring miles per gallon start at the top of a mountain and end in the valley below.It would seem this is going on all the time with tricks played to show a car or any other item for that matter is better than it really is.
Yes. Last night I saw a cheapo extension lead that was well cooked, it had been supplying a 500 watt heater for only a few hours over the past couple of days. The manufacturers could have advertised it asSo back to this extension lead.......
May be some non BS1363 items had been used
