Have just had a Vaillant 637HE system boiler installed with a Unistor 250. Pressure is excellent on 1st floor bathrrom. Problem is when I use the bathroom in the loft pressure is not so good. When both bathrooms are being used the loft bathroom looses almost all the pressure. I though these systems could cope with multiple bathrooms at the same time. Both bathrooms feed off the same 22mm hot pipe. Any ideas? Should each bathroom have its own connection to the cylinder?
Cylinder is installed on a custom built room at back of property on ground floor.
