- Joined
- 27 Jan 2008
- Messages
- 27,521
- Reaction score
- 3,326
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I didn't think commercial radio used side band? Never required a beat frequency oscillator to listen to them, and they don't sound like Donald duck. TV is short for television, tele comes from Latin for distance and vision means some think looked at, so if you have no display there is no vision, so a freeview or freesat set top box is not a television. It does not receive television signals it receives radio signals, those signals may contain coded information which can be turned into some thing that can be viewed but as long as the box does not have a screen there is really no problem.Just be aware that the BBC have iPlayer under the same TV licence requirements as watching live TV.
John,
It's possible to use a diplex or triplex plate to split the TV and FM radio signals from two aerials if your TV has FM reception built in and (of course) you have an FM aerial rigged up.
The sidebands carrying the radio service as part of Freeview come as part of the TV signal. AFAIK, it's not possible to filter in the same kind of way without removing the radio stations as well.
But a Nest mini costs around the same as a set top box, and with a set top box you also need some amplifier and speakers, plus some method to select program wanted. You can link two Nest Mini's to get stereo, and it is so simple to select station, I simply say hay google play radio 4, no buttons, no dials, don't even need to touch it.
So unless you already have the boxes, not worth it.
