and then finding it unnecessary removed it.the previous owner did fit an unnecessary RCD FCU.
( it is be kind to Winston hour here )
and then finding it unnecessary removed it. ( it is be kind to Winston hour here )the previous owner did fit an unnecessary RCD FCU.
Fair enough, but if RCD FCUs are 'smoking', that's presumably due to a design and/or manufacturing problem (which would clearly need to be resolved/rectified), and does not alter the concept of what I was saying.I'm with you John until the reports I've heard on here about the rcd fcu's smoking. I think this worries me more. Maybe that's rare too.
More seriously, as I've just written in another thread, this "unnecessary" is, IMO, open to some debate. IF one believes that RCDs are worthwhile (to protect life and limb), and IF one believes that the in-service failure rate of RCDs is anything like as high as some reports suggest, then there would be a pretty strong case for having two (or more!) in series.
It would be a pain, but does it actually happen? Whatever, my point was a general one about the possible wisdom of having two (or more!) RCDs in series - the problem to which you refer could be eliminated by using RCDs sockets/FCUs etc. which had proper functional switches.Though a lot of these fcu's and sockets use a dual button for off and test, it could be a pain if you trip the circuit every time you turn it off, though i see your point.
As I'm sure you understand, it's not really worth doing any maths - current in a cable 'travels' at a speed approaching the speed of light, so I presume that L-N imbalances will become apparent to a distant RCD roughly that quickly. Light travels at roughly 300,000,000 metres per second (electricity in a cable perhaps about half of that), so you could do the sum yourself (for 10 metres) if you really thought it would be worthwhileI wonder how much faster, if at all an rcd located near an appliance would operate in a fault as opposed to one in the board, 10 metres away. Your good at maths john
As you imply, it's nothing to do with the speed of movement of electrons, which is very slow.Isn't it more of a Newton's Cradle effect? So you stick an electron on one end of the cable and one drops off the other end? So you're not really waiting for an electron to travel the length of the cable at 150,000Km/s or whatever the speed of light in copper is.
