Hi there, hope you can help.
I have a Potterton Prima 50F, about 3-4 yrs old. (Just bought the flat that I was renting so have inherited the system)
I left the flat vacant while doing a ski season for 5 months recently and switch the heating and hot water off completely while away. Upon return the boiler would fire up perfectly but only run for 60-70 seconds before shutting down.
BG man came on his initial Homeserve visit and diagnosed that the pump had seized due to inactivity; he got it going, did the rest of his checks and left with the water and heating running perfectly.
However, I have since discovered that if I run only the hot water on its own, the boiler fires up, runs for 30-35 seconds and the shuts down for about 3 minutes before firing up again and running for a further 30-35 seconds. This continues for the entire programme.
The immersion is not on, the existing water in the system is only warmish and the boiler thermostat is set to 4. As a result the water gets hot but never really hot and I can't help thinking that the repeated cycling on and off will wear out the boiler quicker or be inefficient in gas use and in heating water, be more polluting or all of the above.
Unfortunately I can't remember if it was doing the same thing before I went away.
Thoughts anyone? Thanks in advance.
