pro combi 85he 20 or 21 flashes on fault led HELP
4 Jan 2010
Kent
hi i have had a pro combi 85he installed because me old one went intermittenly hot and cold from sept - march. new one fitted in march and suprise the new one done the same. When i lose the hot water the led flashes 20 times and goes constant on21, it then works fine untill it flashes again.also the boiler sounds like it firering up a flash 9.can any one help.
cheers jason
CONTACTS
Service:
0870 264 1220 option 1
Technical:
0870 264 1220 option 2
Rebadged Vokera IIRC
I dont know and cant find any fault code info online without spending some time at it.
I'll have a 50p bet at good odds that someone has been throwing a new boiler at a dirty system which will end up just killing more boilers if it doesnt get flushed properly
cant get hold off the installer, wonder why! is there any in kent that can help me number is 07834436913 just need it fixed cheers jason
