Problem- 2 way dimmer problems
23 Dec 2006
Sheffield
Fitted a two way dimmer switch and the unit is working, well the light comes on.
Problems
1 the light flickers alot,
2 Light does not go anyway near as bright as before the dimmer was added
3 The dimmer switch buzz's when on
Where have i gone wrong and how do i fix it
lee
Whats the dimmable rating of the switch and what is the type and load(watts) of the lights you are trying to dim?
What wattage and type of lamps go in the light, how many, what voltage?
How have you connected it? Which coloured wire to which terminal?
I'm sorry to pour scorn on your efforts, but if you can't answer these simple questions, you should not be messing about with electricity.
Well in my home we have dimmers in all 3 bedrooms, living room and dining room and we yet have not had one that does not make some sound when in use. :confused:
as i said
breezer said:
good quality dimmers don't
Oh im so sorry.
Anyway back on topic if you have purchased a standard quality dimmer then the buzz is a normal side effect.
i admit apart from annoying, it is normal for some (poor build quality) dimmers, and nothing to worry about
