I have power extended to my garage via an armoured cable and everything has been working OK.
I want to use a powerline/wifi extender in the garage, but it won't work properly because the house sockets (where one powerline adapter is plugged in) and the garage sockets (where the other powerline adapter is plugged in) are on different sides of a split load consumer unit.
This is a known problem and the solution is to move the garage circuit onto the same side as the house sockets.
However when I tried this earlier today, BOTH RCD's tripped when the power was turned back on.
All I did was to move the live wire on the "Garage" MCB to a spare MCB on the other side.
What have I done wrong? Is there anything else I should have done?
