Yes, it's pretty much the only way to determine polarity on a 2 wire AC supply.
... if there is no earth anywhere in the building (or any 'real earth' outside it!) and/or you don't have a long enough lead.Yes, it's pretty much the only way to determine polarity on a 2 wire AC supply.
I agree with sparkwright, too, but I don't think you can call a neon screwdriver a "continuity tester"!Wasn't the 'advice' given on how to determine which is the switched live? So, not really a polarity test and can be done with a continuity tester. Therefore, I agree with Sparkright.
It is a screw type yes, how do I find out which is the switch live mate? I have one of those little screw drivers that can test for current! Will this suffice?
Certainly not a device for proving dead though.
I wouldn't say that.Yes, it's pretty much the only way to determine polarity on a 2 wire AC supply.
IndeedI see now there is some confusion.
Yes, I realise that, that far. However, rather than the other posts you go on to quote, the next relevant one in sequence was:I was commenting on this:It is a screw type yes, how do I find out which is the switch live mate? I have one of those little screw drivers that can test for current! Will this suffice?
... and it was that comment of sparkwright's with which I was agreeingGood enough in this case just to give an indication which is the switched live though, wouldn't you say?The screwdriver testers are not something that is considered as safe or reliable as a test instrument. A two pole voltage indicator would be more appropriate.
Or not?
You shouldn't have one - there's supposed to be a cpc.Yes, it's pretty much the only way to determine polarity on a 2 wire AC supply.
There is a risk that the supply cable has reversed polarity ( black Live ) so this test cannot 100% ensure the correct polarity to the lamp holder.Could you determine the switch live and neutral, using this test? As that is the issue!
