problem with blown paintable wall
BIN stinks but the smell is only alcohol. You could wear a charcoal filtered mask if you want. With the mask on, you won't be able to smell anything.
https://www.amazon.co.uk/Beeswift-BB3030-ABEK-READY-MASK/dp/B00PH53COO
The smell will (almost) completely disappear after about 45 mins (or less).
Just to clarify, I am suggesting that you apply two coats of BIN and then nothing else, ie no emulsion. The main caveat being that BIN can only be tinted to pastel/mid colours and that the colour match will not be exact. Take a sample of your current paint and ask your local decorators' merchant if they can get close to the colour.
Oh I see so the top coat should ideally be oil based paint as well, maybe an eggshell?
If you can get the BIN tinted to the colour you want, just use two coats of BIN. There is no need for anything else. BIN is alcohol not oil based.
I have used oil based eggshell in problem areas in the past but it stinks for ages and eventually yellows.
With regard to protection from water and moisture, oil based paints win, followed by BIN and then followed by waterbased eggshells.
Waterbased eggshells are normally sufficient in bathrooms but it sounds like your bathroom lacks adequate ventilation. I am suggesting a belt and braces approach, you could however treat the crazed areas with either (off the shelf) BIN or oil based undercoat (as recommended by your decorator friend) and then just use your existing emulsion over the top of that and see how you get on. Now that the weather is cooling, you should see if the latter option is suitable within the next 2 or three months.
The cheapest option in the short term is the oil based undercoat and emulsion, it may or may not, however turn out to be the cheapest in the long term.
Good luck either way.
ok i am with you now, thanks
