'Doitall' is one of the most experienced on the forum so he does know what he's talking about....
Condensing or not, all boilers have a HX, its where the heat from the combustion process is transferred into the water. If the HX is partially blocked with sludge the pump cannot dissipate the heated water quickly enough causing the boiler to short cycle.
Immersion needs looking at Possible thermostat failure from the description, this fault has led to fatalities when the contents of the cold storage cistern have been heated by the cylinder and collapsed, showering the room below with boiling water
Hi thanks for the reply, i think the immersion works okay to be honest it's just that the British Gas engineer (couple of years ago) turned the programmer off at the switched fused spur and said that the boiler would heat the water in the cylinder much more cheaply and efficiently. I can turn the immersion programmer/timer thingy back on and it works but water gets very hot and sometimes splutters out of tap with steam when water levels low, not sure if its my eyes but airing cupboard sometimes appears a little steamy when immersion is on, only slightly nothing major...
Matt
