I've had a problem with my washing machine, a Delonghi DL 600 TX model.
During a cycle, there is a 50% chance that it will trip the fuse assigned to the socket. After 1-2 minutes, if I flip the fuse switch it starts working again. The funny part is that once a week the fuse is tripped even when the machine is not working - just plugged in. I've tried using a different socket and the results are the same with the corresponding fuse. Is it a leakage? How deep do i have to check since the fuse is flipped even with the machine is turned off? With a first inside glance, there is no evident damage to any of the cables.
Thanks in advance
Thanks in advance
