We need to eliminate the Salus thermostat from our investigations.
1. Is the receiver's Green Light ON when your boiler goes on with the stat turned low?
2. Does the boiler go out when you turn the receiver OFF, using the switch on the receiver (Red Light goes out]?
If the answer to both is yes, then the problem lies with the thermostat or its wiring. Make sure you have used the SL ON terminal of the Salus receiver.
