Any advice is appreciated on this matter... I have a Mitsubish Delica (basically similar to a Shogun). I left the lights on with this vehicle and know that the battery was flattened in December 2007. I left the car on my drive and did not do anything with it until this week (basically left it flat for 5 months). Rather than push start or use jump leads, I decided to charge the battery up fully for 24 hours.
The car started first time (it also uses Glo plugs) and I left the engine running for 1 hour (I did not drive the vehicle at all). If I turn the engine off and then try to restart the car, it will not start. It just about turns over then stops and then nothing.
I have checked the battery and the cells seem topped up.
I have also charged the battery up fully, left it to stand for 3 days on its own and had the battery tested (it produces 11v out of the maximum 14v).
One piece of advice was that I should have drove the car for 1 hour rather than simply leave the engine running. I am also told that the problem should not be the alternator. I am more inclined to think that the battery is the problem and not the alternator. Can a battery and/or an alternator be ruined by a car being left over winter unused with a flat battery? I would have thought the battery is the cause?
