UPDATE ON THE INSTALLATION FROM HELL::
wired it all up, called for hot water- few seconds for zone valve to open water starts to flow, im thinking yes nearly there. boiler powers up. Fan starts , no ignition. Tried the same with -CH zone valve opens, water begins to flow boiler kicks in fan starts no ignition.
So i swear a bit , if a cat had been near it would have got it, think to meself wiring ok, must be something worng with boiler, go through fault finding and appears to be APS. I remove a hose blow into it, the switch makes and we have a spark and boiler fires.. Replace hose and wont work. I think the venturi may be blocked.
Then to top of it off put the cover on the terminal block, recheck HW nad central heating, and the boiler now wont ccome on. Looks like a loose wire in terminal block. By this time it was 6 o'clock so called it a day.
And to top even that, when i was checking for voltages at thermosat connections etc me mulitmeter probes broke.
I had heard of things going pear shaped but this takes the biscuit,.
Going back tomorro to recheck me wiring and try to unblock venturi. If i cant looks like a \service call as i dont want to do to much digging around and invalidate there warranty.
