Rebuke
Which is the supply side, and which is the load side please?
Will not be able to post till this evening as I am going round to the house!
It should be marked on the back, it should say LOAD N, LOAD L, SUPPLY L and SUPPLY N - or something to that effect.
If switching off the FCU turns everything off then you will have fuses blowing if you put a 3A fuse in. Ideally you want the FCU to protect the lighting circuit only, with a 3A fuse in it.
