Hi there.
I have recently decided to upgrade my non thermostatically controlled, single zone microbore oil fired central heating system to S plan.
I have carried out the follwing work
Placed motorised valve at flow from boiler (28mm myson)
Disconnected old flow and return from Hot water cylinder and capped off with stop ends.
Installed new 22mm flow and return pipes. (mix of hepworth plastic and copper)
Fitted ATC cylinder stat
Fitted 22mm Danfoss valve to Hotwater supply into cylinder
Fitted Danfoss FP715si timeclock and wiring centre.
Fitted Towerstat RSP digital room stat
Fitted new Towel Rail radiator to upstairs bathroom
Fitted new Small convector radiator downstairs.
The problem that I am having is that even with constant venting of the upstairs radiators (4 in total) I cannot get all the air out of upstairs and I only get heat 1/3 of the way up the rads.
Downstairs is piping hot. Even the new rads.
I have tried setting the room stat to 35 degrees and turning off the downstairs rads to get the water flowing well upstairs but to no avail.
Have I done anything wrong?
Thanks in advance to anyone who can help.
P.s. I have 5 radiators downstairs, 4 radiators upstairs, a danfoss s plan pack (with substitute myson valve in place of one of the danfoss), a pump and a warmflow boiler.
Alan
Alan
