A review of the UK product recall system is at https://www.gov.uk/government/uploa...5/ind-16-4-consumer-product-recall-review.pdf
Exactly the same here!Wonderful. My sister has a tumble dryer on the "it may catch fire" list. Hotpoint say it will be 3 months before they can even schedule a visit for the necessary work to be done. In the meantime she may use the tumble dryer, but she must not leave it unattended
With TTC's sister and myself, that makes four!Two people I know have been told "safe if attended".
It actually happened to us with this machine two or three years ago. Whilst the machine was operating 'attended', smoke suddenly started billowing out of the machine. We immediately switched it off and the problem subsided very quickly. I subsequently dismantled the machine and cleaned out the ash and residual fluff that had somehow got past the filter into the ducting, and there has never been a repeat of the problem. I reported the problem to Hotpoint at the time, who thanked me for the report and said that it had been 'noted'.And if it catches fire while you are "attending" it ? Are the early signs of a fire starting large enough to be noticed and still small enough to be safely dealt with. Will turning the power off be enough to allow the fire to subside. ( turning power of at the consumer unit if no safe to access switch by the dryer. )
One imagines that the heating elements are no way near hot enough to ignite fluff when air flow rates are 'normal', and that they will only rise to such a temperature if air flow is impaired (e.g. by a build-up of fluff) - think what happens if the fan of a fan heater stops working.It does seem rather stupid to have heating elements that are hot enough to ignite material when the air being circulated to dry the clothes needs only to be 101° C to obtan rapid drying.
Within seconds an overheat trip cuts the power to the element. ( at least it does on the ones I have bought over the years )think what happens if the fan of a fan heater stops working
Indeed so - but the fan completing stopping is obviously an extreme situation, whereas with the dryer (or is it drier?!) we're only talking about a reduced air flow rate due to partial blockage of the 'air plumbing'. They certainly have overheat protection, so it seems a bit surprising that it doesn't operate before the heating element gets hot enough to ignite fluff.Within seconds an overheat trip cuts the power to the element. ( at least it does on the ones I have bought over the years )think what happens if the fan of a fan heater stops working
Sure - as with fan heaters. However, IIRC the heaters in these dryers do not involve 'naked wire elements' This is a picture of the heater in mine (from a listing of spare parts), and I think what one can see are the fins surrounding an 'enclosed' element (a bit like an immersion heater one):I do not know if this is applicable to the Whirlpool incidents but naked wire elements can ignite fluff even though the overall air temperature is far below the trip temperature of the over heat sensor. Heaters using naked wire elements are the cheapest possible heaters but the wire can glow red hot if the air flow is restricted.
It does. The picture I found and posted was seemingly rather deceptive - as I said, it looked (at least to me) more like fins than the actual element!From the web site http://www.ukanfixit.co.uk/content/creda-hotpoint-tumble-dryer-heating-element-c00206317-2500-watt .... Whch looks like a naked spiral tape element
Speak of the devil! By pure co-incidence, I've just received an e-mail from Hotpoint, which says:Wonderful. My sister has a tumble dryer on the "it may catch fire" list.
... and 'clicking here' gets:...While we cannot provide a definite revised modification date at this time, we are making every effort to have your tumble dryer scheduled for modification as soon as possible. We apologise for this inconvenience and we thank you for your patience. .... Click here for your estimated repair date...
... so your sister's "3 months" sounds pretty good!!Due to high demand it is currently estimated that we will be able to complete the modifications to your tumble dryer in September. We will be in contact with you in due course to arrange the repair visit from our engineer.
