1- ON 00:00 OFF 02:00
2- ON 05:00 OFF 08:00
3- ON 10:00 OFF 12:00
4- ON 16:00 OFF 18:00
5- ON 20:00 OFF 21:00
6- ON 22:00 OFF 23:00
What do you think is going to happen between 02:00 and 05:00, 08:00 and 10:00, 12:00 and 16:00, 18:00 and 20:00, 21:00 and 22:00?
No programmer or programmable stat will allow a void time setting, AFAIK. There are 24 hours in a day, not 15.
Bravo for counting the hours. the void time in the middle is as either I am not home or the house is warm enough until the next Burner start time..
The 901 (wired) and 921 (wireless) are 24 hour programmable thermostats and allow you to set
6 time periods within 24 hours, with just the
start time being set. Based on the above table of what you say you want:
Setting 1 starts at 00:00 at x degrees C
Setting 2 starts at 05:00 at y degrees C, overiding previous setting
Setting 3 starts at 10:00 at x C, overiding previous setting
Setting 4 starts at 16:00 at y C, overiding previous setting
Setting 5 starts at 22:00 at x C , overiding previous setting
That will take you through 'til 00:00, Setting 1, and the cycle starts again.
You have said it yourself there are 3 pairs of On & Off settings. I hope you get it yourself instead trying to explain it to me.
No thermostat will "
close the damn boiler". Thermostats call for heat. When heat is called for by the stat, the boiler will fire up. As i said earlier, the boiler is left permanently
switched on so that the programmable stat controls its on/off periods, either by time or temperature. It will not use gas, nor the pump electricity unless the stat registers that the room temp is below the required temp and calls for heat to raise the temp to the level set. When the temp is at the required level the boiler will be 'off'.
Now I know why you are confused as you think by on and off I mean main power supply to Boiler On/Off ...
NO by On and OFF I mean when the boiler kicks in and start heating the radiators. obviouly boilers are always on and only use gas when the burner kicks in. .... but thanks for trying to explain it to me.
2. Do you have a room thermostat?
I have 5 rooms, 1 kitchen, two halls and two toilets.. I would need 10 thermostats to control individual zones temperatures which I think is may be good solution for other properties for not for me.
Do you not have thermostatic valves on the radiators?
Yes all radiators has thermostatic valves... Please do not come up with something else. Isn't it obvious I am not interested... I just needed to know if I could use a simple time switch with this new boiler or not and it has been answered as YES I can. and have already ordered a digital time switch with 20 settings or I should say 40 in your case
