I've got a leak in the somewhere in the c/h pipes (pressurised system) in the concrete sub floor. I'm proposing to disconnect this pipework from the boiler and tee off the upstairs feed and return pipes coming down the walls to the existing downstairs rads. I'll also have to run a new feed to the hwc as the feed for this is in the floor as well. I have a few questions:-
1. Is there any fundamental reason why I shouldn't do this?
2. Should I use copper or plastic barrier pipe for the new pipework?
3. For the pipes in the wall how deep should I channel them, are there any regs relating to this? Would they need lagging?
4. I'd like to run the pipes behind the skirting once I've come down the wall, any reason not to do this?
5. Finally I'd like to do it in stages, picking up as many rads as I can off each tee from upstairs. Apart from having to drain and refill the system each time is there any good reason not to do this?
All repsonses gratefully received.
