Help and advice please - upgrade to independant h/w and c/h
An ABV does not provide a path unless there is a pump fitted.
A passive path would normally be a gravity cylinder heating coil.
Agreed. But isn't that stating the obvious?
We know the OP has a pump, so what is the point you are trying to make??
A quick update for anyone who's interested - fitted a valve on the H/W water circuit before the tee to the feed and expansion and all seems to be working just fine.
Thanks to all who offered advice - complicated stuff this central heating lark!
Is there still an open path from the boiler to the feed and expansion tee when the valve is closed?
