I am planning to install a woodburning stove in my property. I have no existing chimney so I need to form a new fireplace recess (approx 800mm wide x 800mm high)in the external cavity wall between the house and the attached garage. The stove will sit in the recess with a small masonry chamber (2 sides, a backand a "roof")in the garage to form the rear part of the recess. The flue will connect from the stove to an insulated stainless flue system through the small masonry chamber "roof", up through the garage roof and then up the gable of the house to the termination point . To form the recess I will need to install 2 lintols in the cavity wall. Would I need to first install needles above to support the wall while the lintols are installed underneath (I cant prop from inside the house as the ground floor is a block and beam). Also, I think I would need to submit a building control notice and would they expect calcs for the lintols. Any comments or advice would be gratefully received.
Thank you
Thank you
