it seems they deliver around ¼ of rated output, so seem rather useless.
I get a lot more in summer, of course.
And, if there's ever a sunny, frosty day, they can briefly generate more, because their efficiency is higher when cold.
Option 1 - the vendor buys the scheme out in full before the purchase goes ahead.Turns out the solar panels are on a 'rent a roof' scheme on a 25 year contract through a company called A Shade Greener. I'm not sure what to do now.
Quite a high rate? Umm. Think you’re confusing the FITs payment from the government which you will get if you use the electricity yourself, or export to grid. The pennies you get when it goes to grid is very small, your better off using it yourself. If it’s a rent a roof scheme, the panel owners get the FITs payments, and you just get free lecky.There were two systems.
1. Owned outright.
2. Rent a roof.
You need to find out which via your solicitors.
In either case you use the electricity they produce and the excess is sold the the elect co at quite a high rate. However with rent a roof the renters take that money I believe but they may maintain the panels.
Each panel produces around 250w in bright sunlight when they are new so your 16 could potentially produce 4kW. Output reduces with age but I don't know how much by. Dirt and grime will also reduce the output. I don't like cleaning the car let alone solar panels.
If I was buying a place with solar panels I would welcome it if owned outright, if rent a roof I would probably look for another property.
Yep 2008 or 2009 a friend signed up at 45p for 25 years. However he got nothing other than free power for a year until he had a new meter fitted but I don't think that was the actual reason. His neighbour signed up a couple of years later with exactly the same installation but got about half the amount where the FIT dropped quickly.I believe the FITs payments were fixed for 20years. In 2011 it was around 40p per kWh. 2019 it was more like 4p per kWh.
To get the 45p, a FIT meter must have been installed by the SOLAR installer by the cutoff time. This is the meter that records purely generation. On small scale generation, an import/export meter was not a requirement, a calculation was done on “assumed” export for your extra few pence.Yep 2008 or 2009 a friend signed up at 45p for 25 years. However he got nothing other than free power for a year until he had a new meter fitted but I don't think that was the actual reason. His neighbour signed up a couple of years later with exactly the same installation but got about half the amount where the FIT dropped quickly.
