D
Deleted member 105431
don't listen to george bramwell
All those who do not understand thermal storage, as this fool does not, accuse anyone who does of being a Mr Drivel. I did a search and he does know his stuff. This thread clearly shows that many here do not understand water and heating systems and only know unvented cylinders and system boilers. To advise an unvented cylinder to replace an electric thermal store shows the ignorance of many here. They are easy to spot and it is best to tell them to f***** OFF when they emerge out of the sewers.
BTW, the service charge for an electric only unvented cylinder, will be around £80-100. No one will turn up and work for an hour or two. All controls have to be tested that means boiling the unit by by-pass the immersion stats. £40, only a turn up and look around cowboy will charge that.
I have taken out many unvented cylinders that are scaled up to the hilt and weigh a ton. One was so scaled up it took an eternity to reheat. They had been quoted an arm and a leg to descale it. I replaced it with a DHW only thermal store. The long guarantee meant nothing.
more drivel. So george remind us of your qualifications again. . . .
or do you not have any?
and how many unvented cylinders have you serviced/installed? NONE.
You are a troll.
