Purlin supported by one brick?
5 Nov 2024
Hi.
I am buying a house which is a 1957 bungalow. It's a Hips roof and so there are 4 purlins. The longer purlins of the 4 are both supported by 2 corbels which are made up of about ~10 courses of bricks and seem to be about maybe 400-500mm wide. The weird thing is that the actual purlin is only supported by one brick. That brick has had a notch cut in it for the purlin to sit in.
I want to find out if anyone has seen it done this way before and is it OK? I thought it looked quite sketchy, and so did my surveyor, but I made the mistake of telling him my opinions of the house before he inspected it. I'm worried he is covering himself by agreeing with me in case there is a problem. I have searched the internet and can't find a picture of a purlin supported by a single brick like this. I am new to thinking about buildings though so maybe I didn't search in the right places. All 4 of the corbels are like this and then just have the single brick support.
Thanks for reading this. Any advice would be greatly appreciated.
Been like this since 1890. I'm not too concerned :)
...although this is a terraced house rather than a hipped roof bungalow.
What did the surveyor actually say about the supports?
Thanks for your photo. :)
I looked up his Linkedin profile and he had only been a surveyor for 2 years after being a lettings manager, so I don't know how knowledgeable he is. I don't think he had seen anything like that before. But his report did seem comprehensive, professional, and well thought out. The issue which I didn't mention is that he thinks there has been roof spread. This is based on some internal light cracking in the upper walls and then one actual chunk of plaster about maybe 80mm by 40mm that has become dislodged slightly from an upper wall. The other clue about the house is that the bricks have been repointed with a dark mortar around most of the perimeter of the upper wall. It's the top 3 visible courses of bricks, with there being maybe a further 3-4 courses hidden by the soffits. Basically I had suggested to him that maybe they were trying to hide / fix something and I was suspicious of it. He came up with the idea that it is roof spread. I don't think there is actually visible bowing in any wall though so I am a bit uncertain about what is correct. I had essentially suggested to him that the single brick supports might have been a modification to brace the roof at the same time the darker top perimeter mortar was added. Possibly higher in concrete content to strengthen the upper wall. I have to admit to being new to building stuff though and I have just only in the last 3 months watched a ton of Youtube videos. So I fear I have affected his conclusion. The sellers claim there is no roof spread and they are unaware of a problem.
The other clue I have which the surveyor didn't know is that the owners before the current owners had cavity wall insulation retrofitted in 2005. I couldn't see any holes that had been filled in in any of the walls, and so I have wondered if they had repointed the top bricks as part of that process. I am afraid I have no idea what type of insulation it was. There is no documentation for it.
Here is a picture of a section of the repointing. It is all around the front of the property, the left side and the back. It is not on the right side where there is a carport and a chimney.
The sellers surveyors claims the mortar at the top is a different colour because of shading and rain protection from the soffit. As you can see in the picture, on a sunny day in September this year more of the wall was shaded and there is a clear change in colour at one brick course and not a gradual change as you might expect if the colour change was caused by sun and rain.
What does everyone think? What should I make of my surveyors claim of roof spread, and the sellers surveyors claim of a bit of weather?
Thanks. :)
The way the purlins are supported on just part bricks doesn't look very stable to me.
I'd be happier to see a full length brick doing the supporting, with it reduced in depth lengthwise if required, or any shortfall in thickness made up with something like slate packing
It looks to my eyes, as if the lower level has maybe been repointed, leaving the higher level not repointed.
Are photos 3 (with the vertical timber support) and 4 (with the one brick support), directly opposite each other? Both doing the same job, though by different means?
That looks like an over-lapped joint, between two sections of purlin?
Apologies to OP - yes, two separate purlins, one is mine, one is the neighbours. It's how all the terraces around my way are built - open to each other.
I have since repointed the brickwork and built a firewall to next door... and vacuumed!
