Hi
I've read the wiring diagram thread and tried a few variations but I'm still puzzled.
I have a kitchen/dining room as one room with one light fitting over each area. Currently one switch turns these lights on and off. I would like to replace this one switch for a 2 switch plate and have the two light fittings able to switch on/off independently.
I've done a diagram to better explain and as you can see, currently at the switch is 1 three core and earth cable (blue,yellow,red,earth).
At the kitchen light fitting are 3 cables: 1 three core and earth and 2 two core and earth (red,black,earth).
At the dining room light fitting is 1 cable, a two core and earth (red,black earth).
Can I have them switched independently and if so how would I wire the lot?
I've put letters on each terminal to make explanations easier, I'm not that bright!
Cheers
Steve
Cheers
Steve
