hi all new on this forum and looking for some help with above project.
I want to a OSO unvented indirect stainless cylinder as a thermal store to preheat water before it goes to my boiler. This will run off the emmersion heater controlled by a switch to turn on the heater when electricity is going back to the grid from our PV SYSTEM when we are not using the electricity.
What I want help with, do I use the 210 Ltrs of stored water to connect to the boiler or use the coil inside the cylinder in reverse?
Also how would I wire in a pipe thermostat with a pump to only pump this water to the boiler when it is up to temperature? A wiring diagram would help please.
