Mudster said:thats why i say mix with cement and sand and this has the same effect a sbr it stops the pva coming alive, its been done for years before they put it in a fancy tub and renamed it. applying with a roller and the sand will provide the key.
Actually if you take a look at the post you made on the rendering thread where you cut and pasted the PVA breakdown of / uses from that university type, you'll find that SBR is a polymer modified version of PVA, in so much as it has other chemicals in it.
Adding sand and or cement to PVA isn't doing the same thing. The fact remains that PVA isn't compatible with tile adhesives full stop, you seem to be struggling to grasp this idea.
i agree there are other chemicals added and its not the same but has the same effect. Out of interest and i presume you know your **** by reading your posts, what did they use years ago.
