Hi
Have looked around posts about this but not quite sure adjustment I need. The door has for some time been hard to lock (lifting handle, needs pushed very hard up before key will turn) and now the door is starting to catch at the top right hand corner, hinges being on the left. They are flag hinges and posts suggest to lower the door, which I assume I have to do, I adjust the allen screws underneath the hinges. I have tried this but don't see any change in door position ie still catches. Any ideas what else I should be doing? I know the issue around toe and heel but want to try and adjust by the hinges if I can. Thanks.
